Ana içeriğe geç
Toshiba Satellite L655D-S5095 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L655D-S5095 Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 1. Toshiba Satellite L655D-S5095 Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 2.
    • Unscrew the two screws holding the panel over the hard drive using a Phillips screwdriver. The panel is located on the top right of the laptop's underside.
  2. Toshiba Satellite L655D-S5095 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Remove the cover, firmly lifting from the indent. It is recommended that you leave the screws in the panel.
  3. Toshiba Satellite L655D-S5095 Hard Drive Replacement: adım 3, 2 resimden 1. Toshiba Satellite L655D-S5095 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Remove the screw located under the plastic tab.
  4. Toshiba Satellite L655D-S5095 Hard Drive Replacement: adım 4, 2 resimden 1. Toshiba Satellite L655D-S5095 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Remove the hard drive by pulling the tab upwards and sliding the hard drive out.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Jerry Wakai
377 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-7, Maness Winter 2013 Cal Poly, Team 7-7, Maness Winter 2013 üyesi
CPSU-MANESS-W13S7G7
5 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 25
Her zaman: 3,938
