Ana içeriğe geç
Toshiba Satellite L655D-S5095 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L655D-S5095 RAM Replacement, RAM: adım 1, 2 resimden 1. Toshiba Satellite L655D-S5095 RAM Replacement, RAM: adım 1, 2 resimden 2.
    • Unscrew the three 4.6 mm screws holding the panel using a #1 size Phillips head screwdriver. The panel is centered on the bottom of the laptop.
  2. Toshiba Satellite L655D-S5095 RAM Replacement: adım 2, 1 resimden 1.
    • Remove the cover, firmly lifting from the indent. It is recommended that you leave the screws in the panel.
  3. Toshiba Satellite L655D-S5095 RAM Replacement: adım 3, 3 resimden 1. Toshiba Satellite L655D-S5095 RAM Replacement: adım 3, 3 resimden 2. Toshiba Satellite L655D-S5095 RAM Replacement: adım 3, 3 resimden 3.
    • Push the two tabs outwards, away from the RAM. The RAM should spring up.
  4. Toshiba Satellite L655D-S5095 RAM Replacement: adım 4, 3 resimden 1. Toshiba Satellite L655D-S5095 RAM Replacement: adım 4, 3 resimden 2. Toshiba Satellite L655D-S5095 RAM Replacement: adım 4, 3 resimden 3.
    • Pull the top RAM stick out gently.
    • Repeat steps 3 and 4 for the bottom RAM stick.
    • When installing the new RAM, line up the notches in the RAM's contacts and insert it at the same angle you removed it.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Jerry Wakai
377 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-7, Maness Winter 2013 Cal Poly, Team 7-7, Maness Winter 2013 üyesi
CPSU-MANESS-W13S7G7
5 Üyeler
6 adet Kılavuz yazıldı
2 Yorum
Thank-You! So Much!
Sandra Crockett - Yanıt
Awesome & Simple! Thank-you! My Model is a Satellite P105-S6147 1GBX2 DDR2-666 Sodimm 2BG Total.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 3,719
