Ana içeriğe geç
Toshiba Satellite L655D-S5095 Screen Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L655D-S5095 Screen Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite L655D-S5095 Screen Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite L655D-S5095 Screen Replacement, Battery: adım 1, 3 resimden 3.
    • Locate the battery locks on the bottom of the laptop.
    • Slide the right lock outwards, until it locks into place.
    • Slide and hold the left lock outwards and hold it in place.
  2. Toshiba Satellite L655D-S5095 Screen Replacement: adım 2, 1 resimden 1.
    • While holding the lock in place, slide the battery out towards you.
  3. Toshiba Satellite L655D-S5095 Screen Replacement, Keyboard: adım 3, 1 resimden 1.
    • Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
  4. Toshiba Satellite L655D-S5095 Screen Replacement: adım 4, 1 resimden 1.
    • Use a plastic opening tool to pry off the plastic panel above the keyboard.
  5. Toshiba Satellite L655D-S5095 Screen Replacement: adım 5, 2 resimden 1. Toshiba Satellite L655D-S5095 Screen Replacement: adım 5, 2 resimden 2.
    • Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver.
  6. Toshiba Satellite L655D-S5095 Screen Replacement: adım 6, 1 resimden 1.
    • Slowly lift the keyboard out, up and towards the screen.
    • Do not try to remove the keyboard completely because it is still attached to the motherboard.
  7. Toshiba Satellite L655D-S5095 Screen Replacement: adım 7, 1 resimden 1.
    • Using a plastic opening tool, flip the ZIF connector up to release the ribbon and the keyboard.
  8. Toshiba Satellite L655D-S5095 Screen Replacement, Screen: adım 8, 2 resimden 1. Toshiba Satellite L655D-S5095 Screen Replacement, Screen: adım 8, 2 resimden 2.
    • Remove stickers from four corners of laptop.
    • Remove screws underneath stickers.
  9. Toshiba Satellite L655D-S5095 Screen Replacement: adım 9, 2 resimden 1. Toshiba Satellite L655D-S5095 Screen Replacement: adım 9, 2 resimden 2.
    • Use plastic opening tool to pry the hinges off.
    • Remove the screen cover.
    • Unscrew the six screws on the bottom of the screen near the top of the hinges.
  10. Toshiba Satellite L655D-S5095 Screen Replacement: adım 10, 2 resimden 1. Toshiba Satellite L655D-S5095 Screen Replacement: adım 10, 2 resimden 2.
    • Remove cable located next to the fan.
    • Fold down screen without screen back cover to remove cable as shown.
  11. Toshiba Satellite L655D-S5095 Screen Replacement: adım 11, 2 resimden 1. Toshiba Satellite L655D-S5095 Screen Replacement: adım 11, 2 resimden 2.
    • Unscrew both screws on each side of the screen.
    • Remove the screen.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Christopher Camara
194 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-4, Calaway Spring 2014 UMass Dartmouth, Team 4-4, Calaway Spring 2014 üyesi
UMASSD-CALAWAY-S14S4G4
4 Üyeler
2 adet Kılavuz yazıldı
1Rehber Yorum
Que éxito esta pagina , muy gran trabajo, soy de Perú y creo que este tipo de trabajos son muy bien valorados, saludos a la distancia.
Korregan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 29
Her zaman: 2,347
