Ana içeriğe geç
Toshiba Satellite L675D-S7016 Disk Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L675D-S7016 Disk Drive Replacement, Back Panel Removal: adım 1, 1 resimden 1.
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  2. Toshiba Satellite L675D-S7016 Disk Drive Replacement: adım 2, 2 resimden 1. Toshiba Satellite L675D-S7016 Disk Drive Replacement: adım 2, 2 resimden 2.
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
  3. Toshiba Satellite L675D-S7016 Disk Drive Replacement, Disk Drive: adım 3, 1 resimden 1.
    • Remove the single 5mm Phillips #1 screw using the screwdriver.
  4. Toshiba Satellite L675D-S7016 Disk Drive Replacement: adım 4, 2 resimden 1. Toshiba Satellite L675D-S7016 Disk Drive Replacement: adım 4, 2 resimden 2.
    • Push the exposed portion of the Disk Drive outwards.
    • The Disk Drive will begin sliding out of its slot. Remove Disk Drive from the laptop by hand.
  5. Toshiba Satellite L675D-S7016 Disk Drive Replacement: adım 5, 2 resimden 1. Toshiba Satellite L675D-S7016 Disk Drive Replacement: adım 5, 2 resimden 2.
    • This step is only necessary if there is a disc stuck inside the drive! If you are replacing the drive and do not need to remove a disc, this can be skipped.
    • On the front of the Disk Drive, below the eject button, insert a pin or paperclip into the hole.
    • Push the pin into hole until the Disk Drive pops out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Austin Bons
1.131 İtibar
8 adet Kılavuz yazıldı
Ekip
UC Davis, Team 2-2, Oliver Fall 2016 UC Davis, Team 2-2, Oliver Fall 2016 üyesi
UCD-OLIVER-F16S2G2
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 342
