Giriş
If you have determined that your Disk Drive is faulty, this guide will walk you through the removal steps. This piece of the laptop is easily removed and reinstalled. An easy fix for novices.
Neye ihtiyacın var
Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
Bir başkası bu kılavuzu tamamladı.
