Ana içeriğe geç
Toshiba Satellite L675D-S7016 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L675D-S7016 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 Keyboard Replacement: adım 2, 1 resimden 1.
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 Keyboard Replacement: adım 3, 3 resimden 1. Toshiba Satellite L675D-S7016 Keyboard Replacement: adım 3, 3 resimden 2. Toshiba Satellite L675D-S7016 Keyboard Replacement: adım 3, 3 resimden 3.
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Toshiba Satellite L675D-S7016 Keyboard Replacement, Keyboard: adım 4, 3 resimden 1. Toshiba Satellite L675D-S7016 Keyboard Replacement, Keyboard: adım 4, 3 resimden 2. Toshiba Satellite L675D-S7016 Keyboard Replacement, Keyboard: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Heavy-Duty Spudger
    • Pry under the plastic strip, starting on the top right side of the key board with a Heavy Duty Spudger.
    • Once the first corner is raised, use your hand pulling upwards and release the rest of the strip.
  5. Toshiba Satellite L675D-S7016 Keyboard Replacement: adım 5, 2 resimden 1. Toshiba Satellite L675D-S7016 Keyboard Replacement: adım 5, 2 resimden 2.
    • Remove the first 3mm screw with the Phillips #1 screwdriver.
    • Remove the next three 3mm screws.
  6. Toshiba Satellite L675D-S7016 Keyboard Replacement: adım 6, 2 resimden 1. Toshiba Satellite L675D-S7016 Keyboard Replacement: adım 6, 2 resimden 2.
    • Lift the keyboard gently . Slide it forward towards the screen and speakers. This reveals the connection needed for the next step.
  7. Toshiba Satellite L675D-S7016 Keyboard Replacement: adım 7, 3 resimden 1. Toshiba Satellite L675D-S7016 Keyboard Replacement: adım 7, 3 resimden 2. Toshiba Satellite L675D-S7016 Keyboard Replacement: adım 7, 3 resimden 3.
    • Use the pointed end of the Heavy-Duty Spudger and push the pins toward the screen, leaving them in this position.
    • Carefully slide the connector out of the port.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Austin Bons
1.131 İtibar
8 adet Kılavuz yazıldı
Ekip
UC Davis, Team 2-2, Oliver Fall 2016 UC Davis, Team 2-2, Oliver Fall 2016 üyesi
UCD-OLIVER-F16S2G2
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 19
Son 30 gün: 19
Her zaman: 837
