Ana içeriğe geç
Toshiba Satellite L675D-S7016 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L675D-S7016 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 RAM Replacement: adım 2, 1 resimden 1.
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 RAM Replacement: adım 3, 3 resimden 1. Toshiba Satellite L675D-S7016 RAM Replacement: adım 3, 3 resimden 2. Toshiba Satellite L675D-S7016 RAM Replacement: adım 3, 3 resimden 3.
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Toshiba Satellite L675D-S7016 RAM Replacement, Back Panel Removal: adım 4, 1 resimden 1.
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  5. Toshiba Satellite L675D-S7016 RAM Replacement: adım 5, 2 resimden 1. Toshiba Satellite L675D-S7016 RAM Replacement: adım 5, 2 resimden 2.
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
  6. Toshiba Satellite L675D-S7016 RAM Replacement, RAM: adım 6, 3 resimden 1. Toshiba Satellite L675D-S7016 RAM Replacement, RAM: adım 6, 3 resimden 2. Toshiba Satellite L675D-S7016 RAM Replacement, RAM: adım 6, 3 resimden 3.
    • Using your fingers, spread the spring tabs holding the top stick of RAM in place.
    • Once the tabs are spread apart, the stick of RAM will pop up.
    • Remove the first stick of RAM by pulling out along the same angle the RAM stick springs up.
  7. Toshiba Satellite L675D-S7016 RAM Replacement: adım 7, 3 resimden 1. Toshiba Satellite L675D-S7016 RAM Replacement: adım 7, 3 resimden 2. Toshiba Satellite L675D-S7016 RAM Replacement: adım 7, 3 resimden 3.
    • Repeat the same procedure to remove the second stick of RAM.
Sonuç
Austin Bons
1.131 İtibar
8 adet Kılavuz yazıldı
Ekip
UC Davis, Team 2-2, Oliver Fall 2016 UC Davis, Team 2-2, Oliver Fall 2016 üyesi
UCD-OLIVER-F16S2G2
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 588
