Giriş
If you determined that the LCD screen is unresponsive, or "black," this guide will show you how to access and remove the screen.
Neye ihtiyacın var
Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
Slide the hard drive to the left, using the silver tab.
Pull up the silver tab, removing the hard drive from the slot.
Using your fingers, spread the spring tabs holding the top stick of RAM in place.
Once the tabs are spread apart, the stick of RAM will pop up.
Remove the first stick of RAM by pulling out along the same angle the RAM stick springs up.
Bu adımda kullanılan alet:Heavy-Duty Spudger$4.99
Pry under the plastic strip, starting on the top right side of the key board with a Heavy Duty Spudger.
Once the first corner is raised, use your hand pulling upwards and release the rest of the strip.
Remove the following screws with a Phillips #1 screwdriver.
Seventeen 5mm screws (recessed)
Three 2mm screws in the battery bay (flush-mounted)
Single 5mm screw does not need removal unless working on the screen
2 farklı kişi bu kılavuzu tamamladı.
