Ana içeriğe geç
Toshiba Satellite L755-S5244 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L755-S5244 RAM Replacement, RAM: adım 1, 2 resimden 1. Toshiba Satellite L755-S5244 RAM Replacement, RAM: adım 1, 2 resimden 2.
    • Loosen the two 3mm Phillips #0 screws securing the hard drive panel. The panel will retain the screws, so do not remove them completely.
    • Remove the panel from the laptop (the hard drive does not need to be removed).
  2. Toshiba Satellite L755-S5244 RAM Replacement: adım 2, 2 resimden 1. Toshiba Satellite L755-S5244 RAM Replacement: adım 2, 2 resimden 2.
    • Loosen the three 3mm Phillips #0 screws that secure the center panel. The screws are retained by the cover, so do not remove them completely.
    • Remove the panel by pulling out to the right.
    • The two RAM sticks are stacked, one on top of the other.
  3. Toshiba Satellite L755-S5244 RAM Replacement: adım 3, 2 resimden 1. Toshiba Satellite L755-S5244 RAM Replacement: adım 3, 2 resimden 2.
    • Each RAM stick has two (2) snap locks, one on each end. In the image the bottom snap is obscured by the cable.
  4. Toshiba Satellite L755-S5244 RAM Replacement: adım 4, 1 resimden 1.
    • Move the retaining clips out of their locking position, allowing the RAM stick to pop up.
    • Lift the free end of the RAM stick until the stick can be freely removed from its slot.
  5. Toshiba Satellite L755-S5244 RAM Replacement: adım 5, 1 resimden 1.
    • The RAM stick has a notch that is not centered on the stick. Be sure to take note of the RAM stick's orientation for reinstallation
  6. Toshiba Satellite L755-S5244 RAM Replacement: adım 6, 1 resimden 1.
    • Repeat for the second RAM stick.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 331
