Ana içeriğe geç
Toshiba Satellite L755D-S5150 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L755D-S5150 Keyboard Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite L755D-S5150 Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
  2. Toshiba Satellite L755D-S5150 Keyboard Replacement, Keyboard: adım 2, 1 resimden 1.
    • Using the plastic opening tool carefully pry the plastic strip that sits at the top of the keyboard.
  3. Toshiba Satellite L755D-S5150 Keyboard Replacement: adım 3, 1 resimden 1.
    • Use the Phillips PH00 to unscrew the four 4mm screws that holds the keyboard in place.
    • Using the plastic opening tool carefully pry your keyboard out without disturbing the cord underneath it.
  4. Toshiba Satellite L755D-S5150 Keyboard Replacement: adım 4, 1 resimden 1.
    • Remaining is the cord that connects the keyboard to the motherboard. Remove this cord after the tabs are pressed in that releases keyboard.
Sonuç
Replace after you are done with your goal replacement.
Bir başkası bu kılavuzu tamamladı.
Shaheedah
276 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-5, Sullivan Fall 2016 USF Tampa, Team 2-5, Sullivan Fall 2016 üyesi
USFT-SULLIVAN-F16S2G5
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 879
