Ana içeriğe geç
Toshiba Satellite L755D-S5150 Motherboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L755D-S5150 Motherboard Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite L755D-S5150 Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
  2. Toshiba Satellite L755D-S5150 Motherboard Replacement, Keyboard: adım 2, 1 resimden 1.
    • Using the plastic opening tool carefully pry the plastic strip that sits at the top of the keyboard.
  3. Toshiba Satellite L755D-S5150 Motherboard Replacement: adım 3, 1 resimden 1.
    • Use the Phillips PH00 to unscrew the four 4mm screws that holds the keyboard in place.
    • Using the plastic opening tool carefully pry your keyboard out without disturbing the cord underneath it.
  4. Toshiba Satellite L755D-S5150 Motherboard Replacement: adım 4, 1 resimden 1.
    • Remaining is the cord that connects the keyboard to the motherboard. Remove this cord after the tabs are pressed in that releases keyboard.
  5. Toshiba Satellite L755D-S5150 Motherboard Replacement, Motherboard: adım 5, 2 resimden 1. Toshiba Satellite L755D-S5150 Motherboard Replacement, Motherboard: adım 5, 2 resimden 2.
    • Using the Phillips PH00 screwdriver remove the three 4mm screws from the cover for the RAM.
    • Use the Phillips PH00 to remove the one 4mm screw that holds the ODD.
    • Slide the ODD outward.
    • Removing the RAM is not necessary
    • The ODD is also commonly referred to as a CD-ROM.
  6. Toshiba Satellite L755D-S5150 Motherboard Replacement: adım 6, 1 resimden 1.
    • Use the Phillips PH00 screwdriver to remove one 4mm screw.
    • Use the Phillips PH00 screwdriver to remove the two 3mm screws from the fan.
    • The motherboard will be accessed from below the keyboard, therefore you will not need to take out the bottom of the laptop.
  7. Toshiba Satellite L755D-S5150 Motherboard Replacement: adım 7, 1 resimden 1.
    • Use the Phillips PH00 to unscrew the fifteen 4mm screws holding down the motherboard.
  8. Toshiba Satellite L755D-S5150 Motherboard Replacement: adım 8, 2 resimden 1. Toshiba Satellite L755D-S5150 Motherboard Replacement: adım 8, 2 resimden 2.
    • Lift the motherboard and disconnect the 4 pin connector on the bottom side.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Shaheedah
276 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-5, Sullivan Fall 2016 USF Tampa, Team 2-5, Sullivan Fall 2016 üyesi
USFT-SULLIVAN-F16S2G5
4 Üyeler
5 adet Kılavuz yazıldı
1Rehber Yorum
This my laptop for now .
mouhmmad ghassan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 1,087
