Ana içeriğe geç
Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Battery: adım 1, 2 resimden 2.
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
  2. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Keyboard: adım 2, 1 resimden 1.
    • Using the plastic opening tool carefully pry the plastic strip that sits at the top of the keyboard.
  3. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: adım 3, 1 resimden 1.
    • Use the Phillips PH00 to unscrew the four 4mm screws that holds the keyboard in place.
    • Using the plastic opening tool carefully pry your keyboard out without disturbing the cord underneath it.
  4. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: adım 4, 1 resimden 1.
    • Remaining is the cord that connects the keyboard to the motherboard. Remove this cord after the tabs are pressed in that releases keyboard.
  5. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Optical Disc Drive: adım 5, 1 resimden 1.
    • Use the screwdiver and the Phillips PH00 to unscrew the three, 4mm screws for the RAM compartment
  6. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: adım 6, 2 resimden 1. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: adım 6, 2 resimden 2.
    • Use the Phillips PH00 to remove the 4mm screw that holds the ODD.
    • Slide the ODD outward.
  7. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: adım 7, 1 resimden 1.
    • Remove the two 4mm screws and the plate attached to the ODD.
Sonuç
Michael Griskewicz
159 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 2-5, Sullivan Fall 2016 USF Tampa, Team 2-5, Sullivan Fall 2016 üyesi
USFT-SULLIVAN-F16S2G5
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 346
