Giriş
Usually if your Optical Disc Drive(ODD) needs to be replaced it means that your disks aren't being read, a noisy sound from the ODD, or maybe it just isn't taking the disk. It's good to make sure your computer's software is updated before you replace the ODD. As this can sometime solve your issue.
Neye ihtiyacın var
After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
Using the plastic opening tool carefully pry the plastic strip that sits at the top of the keyboard.
Use the screwdiver and the Phillips PH00 to unscrew the three, 4mm screws for the RAM compartment
