Ana içeriğe geç
Toshiba Satellite L755D-S5150 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L755D-S5150 RAM  Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite L755D-S5150 RAM  Replacement, Battery: adım 1, 2 resimden 2.
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
  2. Toshiba Satellite L755D-S5150 RAM  Replacement, RAM Chip: adım 2, 3 resimden 1. Toshiba Satellite L755D-S5150 RAM  Replacement, RAM Chip: adım 2, 3 resimden 2. Toshiba Satellite L755D-S5150 RAM  Replacement, RAM Chip: adım 2, 3 resimden 3.
    • Using the Phillips PH00 screwdriver unscrew the three 4mm screws for the cover of the Ram compartment.
    • Now remove the cover for the Ram compartment.
  3. Toshiba Satellite L755D-S5150 RAM  Replacement: adım 3, 2 resimden 1. Toshiba Satellite L755D-S5150 RAM  Replacement: adım 3, 2 resimden 2.
    • Using both hands, gently push the two metal claps on either side of the top RAM chip outward.
    • The RAM chip will then pop up at an angle, allowing you to pull it out.
    • Repeat the above step for the second RAM chip
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kyler Clonts
258 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-5, Sullivan Fall 2016 USF Tampa, Team 2-5, Sullivan Fall 2016 üyesi
USFT-SULLIVAN-F16S2G5
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 409
