Ana içeriğe geç
Toshiba Satellite L775D-S7340 CMOS Battery Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L775D-S7340 CMOS Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the laptop is unplugged and powered off.
    • Locate the battery latches on the underside of the laptop.
  2. Toshiba Satellite L775D-S7340 CMOS Battery Replacement: adım 2, 1 resimden 1.
    • Slide the right latch to the right until you hear it lock into place.
    • Slide the left latch to the left and hold it.
  3. Toshiba Satellite L775D-S7340 CMOS Battery Replacement: adım 3, 1 resimden 1.
    • Slide the battery out towards you.
  4. Toshiba Satellite L775D-S7340 CMOS Battery Replacement, CMOS Battery: adım 4, 1 resimden 1.
    • Use the Phillips #1 screwdriver to remove the one 4.6 mm screw holding on the cover located on the bottom center of the laptop.
  5. Toshiba Satellite L775D-S7340 CMOS Battery Replacement: adım 5, 1 resimden 1.
    • Use the plastic opening tool to pry open the CMOS battery cover. Wedge the prying tool in, beginning at the indent in the cover.
  6. Toshiba Satellite L775D-S7340 CMOS Battery Replacement: adım 6, 1 resimden 1.
    • Use another prying tool to pry up along the edges of the cover. Continue prying up around the edges until the cover is open and remove it.
  7. Toshiba Satellite L775D-S7340 CMOS Battery Replacement: adım 7, 1 resimden 1.
    • Using the pointed side of the spudger, remove the CMOS battery by pushing down on the tab that secures the battery in place.
    • The CMOS battery should pop up or out of its holder.
Sonuç
Elizabeth Sadewasser
498 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 27
Her zaman: 6,146
