Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This guide will show you how to remove and replace the keyboard.
  1. Make sure the laptop is unplugged and powered off.
    • Make sure the laptop is unplugged and powered off.
    • Locate the battery latches on the underside of the laptop.
  2. Slide the right latch to the right until you hear it lock into place.
    • Slide the right latch to the right until you hear it lock into place.
    • Slide the left latch to the left and hold it.
  3. Slide the battery out towards you.
    • Slide the battery out towards you.
  4. Pry up the thin narrow strip of facing above the keyboard using the opening tool.
    • Pry up the thin narrow strip of facing above the keyboard using the opening tool.
  5. Remove the four screws securing the keyboard using the T4 Torx screwdriver,
    • Remove the four screws securing the keyboard using the T4 Torx screwdriver,
  6. Lift the keyboard slowly using the opening tool and lean it toward  touchpad. It will still be held by the connector ribbon. Make sure not to pull out the connector ribbon.
    • Lift the keyboard slowly using the opening tool and lean it toward touchpad.
    • It will still be held by the connector ribbon. Make sure not to pull out the connector ribbon.
  7. The ribbon is attached by a white clip. Wedge the white clip up carefully using the spudger. This will release the connector ribbon and you can now remove the keyboard.
    • The ribbon is attached by a white clip. Wedge the white clip up carefully using the spudger. This will release the connector ribbon and you can now remove the keyboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Madeline Park
441 İtibar
4 adet Kılavuz yazıldı
Takım
Bir Yorum
I need to know how to change a plasma for a Toshiba Satellite L775D-S7340
Cyndi May Evans - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 1,249
