Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Make sure the laptop is unplugged and powered off.
Locate the battery latches on the underside of the laptop.
Slide the right latch to the right until you hear it lock into place.
Slide the left latch to the left and hold it.
Pry up the thin narrow strip of facing above the keyboard using the opening tool.
Remove the four screws securing the keyboard using the T4 Torx screwdriver,
Lift the keyboard slowly using the opening tool and lean it toward touchpad.
The ribbon is attached by a white clip. Wedge the white clip up carefully using the spudger. This will release the connector ribbon and you can now remove the keyboard.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
I need to know how to change a plasma for a Toshiba Satellite L775D-S7340
