Ana içeriğe geç
Toshiba Satellite L855-S5119 Optical Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L855-S5119 Optical Drive Replacement, Back Plate Removal: adım 1, 3 resimden 1. Toshiba Satellite L855-S5119 Optical Drive Replacement, Back Plate Removal: adım 1, 3 resimden 2. Toshiba Satellite L855-S5119 Optical Drive Replacement, Back Plate Removal: adım 1, 3 resimden 3.
    • Turn the laptop over to place it top down.
    • Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
    • Lift the back plate off the laptop, exposing the RAM and Hard Disk.
  2. Toshiba Satellite L855-S5119 Optical Drive Replacement, Optical Drive: adım 2, 2 resimden 1. Toshiba Satellite L855-S5119 Optical Drive Replacement, Optical Drive: adım 2, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the single 3mm screw.
  3. Toshiba Satellite L855-S5119 Optical Drive Replacement: adım 3, 2 resimden 1. Toshiba Satellite L855-S5119 Optical Drive Replacement: adım 3, 2 resimden 2.
    • Rotate the laptop so that you have access to the optical drive.
    • The optical drive is now only attached by a port in the drive's back. The optical drive can be pulled straight out of its housing.
    • Remove the drive.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tyler Shafer
426 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 248
