Ana içeriğe geç
Toshiba Satellite L875D-S7210 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L875D-S7210 Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Starting on either side, use a metal spudger to pry out the long, narrow plastic covering at the bottom of the keyboard.
  2. Toshiba Satellite L875D-S7210 Keyboard Replacement: adım 2, 1 resimden 1.
    • Gently remove the plastic strip from the keyboard.
  3. Toshiba Satellite L875D-S7210 Keyboard Replacement: adım 3, 1 resimden 1.
    • Using your hands, gently lift the keyboard out of the computer. The keyboard will still be attached to the computer so be careful not to pull too hard.
  4. Toshiba Satellite L875D-S7210 Keyboard Replacement: adım 4, 1 resimden 1.
    • Find the ribbon cable that connects the keyboard to the computer.
  5. Toshiba Satellite L875D-S7210 Keyboard Replacement: adım 5, 2 resimden 1. Toshiba Satellite L875D-S7210 Keyboard Replacement: adım 5, 2 resimden 2.
    • Place the metal spudger underneath the lockable connector.
    • Lift up to unlock the lockable connector
    • Remove the ribbon cable from the keyboard and you will have successfully removed from your laptop. Reverse this process to attach the new keyboard.
Sonuç
Ian M Sloop
667 İtibar
4 adet Kılavuz yazıldı
Ekip
UC Davis, Team S7-G7, Lore Fall 2018 UC Davis, Team S7-G7, Lore Fall 2018 üyesi
UCD-LORE-F18S7G7
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 776
