Ana içeriğe geç
Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Unlatch the battery by pushing outward on both latches.
  2. Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement: adım 2, 1 resimden 1.
    • Slide battery out.
  3. Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement, CD/DVD Drive: adım 3, 1 resimden 1.
    • Remove the back panel by removing the three labeled screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement: adım 4, 2 resimden 1. Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement: adım 4, 2 resimden 2.
    • Locate and remove the circled screw with a Phillips #0 screwdriver.
  5. Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement: adım 5, 1 resimden 1.
    • Use the plastic opening tool to pry the CD/DVD drive out of the frame.
  6. Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement: adım 6, 1 resimden 1.
    • Gently remove the CD/DVD drive from the laptop body.
Sonuç
Michael Jensen
425 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-3, Regan Spring 2011 Cal Poly, Team 4-3, Regan Spring 2011 üyesi
CPSU-REGAN-S11S4G3
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 3,084
