Ana içeriğe geç
Toshiba Satellite M305D-S4829 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite M305D-S4829 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Unlatch the battery by pushing outward on both latches.
  2. Toshiba Satellite M305D-S4829 Keyboard Replacement: adım 2, 1 resimden 1.
    • Slide battery out.
  3. Toshiba Satellite M305D-S4829 Keyboard Replacement, Keyboard: adım 3, 1 resimden 1.
    • Remove the five "F2" screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite M305D-S4829 Keyboard Replacement: adım 4, 2 resimden 1. Toshiba Satellite M305D-S4829 Keyboard Replacement: adım 4, 2 resimden 2.
    • Insert the plastic opening tool above the F1 key.
    • Apply upward pressure until the black plastic strip snaps off. The entire strip will easily come off from left to right.
  5. Toshiba Satellite M305D-S4829 Keyboard Replacement: adım 5, 2 resimden 1. Toshiba Satellite M305D-S4829 Keyboard Replacement: adım 5, 2 resimden 2.
    • Find the screws above the F1 and INS keys.
    • Unscrew both screws with a Phillips #0 screwdriver.
  6. Toshiba Satellite M305D-S4829 Keyboard Replacement: adım 6, 2 resimden 1. Toshiba Satellite M305D-S4829 Keyboard Replacement: adım 6, 2 resimden 2.
    • Slowly lift the top edge of the keyboard out with your fingers.
    • The ribbon cable located on the back of the keyboard will become accessible.
  7. Toshiba Satellite M305D-S4829 Keyboard Replacement: adım 7, 2 resimden 1. Toshiba Satellite M305D-S4829 Keyboard Replacement: adım 7, 2 resimden 2.
    • Locate the black ribbon cable flap.
    • Detach flap with plastic opening tool. The ribbon cable will become free.
  8. Toshiba Satellite M305D-S4829 Keyboard Replacement: adım 8, 1 resimden 1.
    • Your keyboard has now been successfully removed.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Michael Jensen
425 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-3, Regan Spring 2011 Cal Poly, Team 4-3, Regan Spring 2011 üyesi
CPSU-REGAN-S11S4G3
5 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 4,582
