Ana içeriğe geç
Toshiba Satellite M305D-S4829 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite M305D-S4829 RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Unscrew the three screws from the back panel with Phillips #0 screwdriver.
    • Remove the back panel.
  2. Toshiba Satellite M305D-S4829 RAM Replacement: adım 2, 3 resimden 1. Toshiba Satellite M305D-S4829 RAM Replacement: adım 2, 3 resimden 2. Toshiba Satellite M305D-S4829 RAM Replacement: adım 2, 3 resimden 3.
    • Locate the two clips holding the RAM chip in place.
    • Apply pressure to each clip, pulling them away from the RAM.
    • One end of the RAM will pop out.
  3. Toshiba Satellite M305D-S4829 RAM Replacement: adım 3, 2 resimden 1. Toshiba Satellite M305D-S4829 RAM Replacement: adım 3, 2 resimden 2.
    • Gently pull RAM out as shown.
  4. Toshiba Satellite M305D-S4829 RAM Replacement: adım 4, 1 resimden 1.
    • To intall a new stick of RAM, carefully insert it into into the RAM slot.
    • Gently push down on the RAM chip until it snaps securely into place.
Sonuç
Michael Jensen
425 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-3, Regan Spring 2011 Cal Poly, Team 4-3, Regan Spring 2011 üyesi
CPSU-REGAN-S11S4G3
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 9
Her zaman: 2,705
