Ana içeriğe geç
Toshiba Satellite M35X-S114 Battery Replacement
  1. Toshiba Satellite M35X-S114 Battery Replacement, Unlock the Battery from its Compartment: adım 1, 2 resimden 1. Toshiba Satellite M35X-S114 Battery Replacement, Unlock the Battery from its Compartment: adım 1, 2 resimden 2.
    • Locate the battery near the bottom left-hand side of the device.
    • Locate the two switches above the battery's top left corner.
    • Use any finger to move the smaller switch above the battery to the unlock position.
    • A small icon of a padlock will identify the "lock" and "unlock" positions of the switch.
  2. Toshiba Satellite M35X-S114 Battery Replacement, Move the Battery's Release Switch: adım 2, 2 resimden 1. Toshiba Satellite M35X-S114 Battery Replacement, Move the Battery's Release Switch: adım 2, 2 resimden 2.
    • Use any finger to move the larger switch above the battery to the left and hold the switch.
  3. Toshiba Satellite M35X-S114 Battery Replacement, Remove the Battery: adım 3, 2 resimden 1. Toshiba Satellite M35X-S114 Battery Replacement, Remove the Battery: adım 3, 2 resimden 2.
    • Place your fingernail or fingertip into the groove near the top right of the battery.
    • Pull the battery out with your finger. Release the larger switch once the battery is out.
Sonuç
Nathan Jansen
206 İtibar
1 Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-4, Bruce Fall 2014 CSU Fullerton, Team 2-4, Bruce Fall 2014 üyesi
CSUF-BRUCE-F14S2G4
4 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 380
