Ana içeriğe geç
Toshiba Satellite M35X-S114 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite M35X-S114 Hard Drive Replacement, Unlock the Battery from its Compartment: adım 1, 2 resimden 1. Toshiba Satellite M35X-S114 Hard Drive Replacement, Unlock the Battery from its Compartment: adım 1, 2 resimden 2.
    • Locate the battery near the bottom left-hand side of the device.
    • Locate the two switches above the battery's top left corner.
    • Use any finger to move the smaller switch above the battery to the unlock position.
    • A small icon of a padlock will identify the "lock" and "unlock" positions of the switch.
  2. Toshiba Satellite M35X-S114 Hard Drive Replacement, Move the Battery's Release Switch: adım 2, 2 resimden 1. Toshiba Satellite M35X-S114 Hard Drive Replacement, Move the Battery's Release Switch: adım 2, 2 resimden 2.
    • Use any finger to move the larger switch above the battery to the left and hold the switch.
  3. Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Battery: adım 3, 2 resimden 1. Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Battery: adım 3, 2 resimden 2.
    • Place your fingernail or fingertip into the groove near the top right of the battery.
    • Pull the battery out with your finger. Release the larger switch once the battery is out.
  4. Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Hard Drive screw: adım 4, 3 resimden 1. Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Hard Drive screw: adım 4, 3 resimden 2. Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Hard Drive screw: adım 4, 3 resimden 3.
    • Locate the Hard Drive.
    • Locate the screw near the Hard Drive.
    • Use a Phillips 00 screwdriver to remove the 7.50mm screw.
  5. Toshiba Satellite M35X-S114 Hard Drive Replacement, Slide the Hard Drive out: adım 5, 2 resimden 1. Toshiba Satellite M35X-S114 Hard Drive Replacement, Slide the Hard Drive out: adım 5, 2 resimden 2.
    • Please note that the hard drive from the laptop used is missing.
    • Slide the hard drive out.
    • The hard drive may not slide out easily, and may require a little bit of force in order to be disconnected from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Christian Mayorga
219 İtibar
2 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-4, Bruce Fall 2014 CSU Fullerton, Team 2-4, Bruce Fall 2014 üyesi
CSUF-BRUCE-F14S2G4
4 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 1,826
