Ana içeriğe geç
Toshiba Satellite M45 Cooling Unit Replacement
Neye ihtiyacın var
  1. Toshiba Satellite M45 Cooling Unit Replacement, Cooling Unit: adım 1, 3 resimden 1. Toshiba Satellite M45 Cooling Unit Replacement, Cooling Unit: adım 1, 3 resimden 2. Toshiba Satellite M45 Cooling Unit Replacement, Cooling Unit: adım 1, 3 resimden 3.
    • Remove the cover from the cooling unit.
  2. Toshiba Satellite M45 Cooling Unit Replacement: adım 2, 2 resimden 1. Toshiba Satellite M45 Cooling Unit Replacement: adım 2, 2 resimden 2.
    • Unscrew the copper heat-sink using a #1 screwdriver, and then lift it free. Do not get any thermal grease on any components. This part can now be replaced.
  3. Toshiba Satellite M45 Cooling Unit Replacement: adım 3, 1 resimden 1.
    • Follow the tear-down guide until you have access to the fan unit on the motherboard.
  4. Toshiba Satellite M45 Cooling Unit Replacement: adım 4, 3 resimden 1. Toshiba Satellite M45 Cooling Unit Replacement: adım 4, 3 resimden 2. Toshiba Satellite M45 Cooling Unit Replacement: adım 4, 3 resimden 3.
    • Unscrew the fan unit from the motherboard using a #0 screwdriver. Once the fan is unscrewed and unplugged from the motherboard, it can be replaced.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Stephen
370 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-42, Garner Spring 2010 Cal Poly, Team 10-42, Garner Spring 2010 üyesi
CPSU-GARNER-S10S10G42
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 16
Her zaman: 5,488
