Ana içeriğe geç
Toshiba Satellite M45 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite M45 Keyboard Replacement, Keyboard: adım 1, 3 resimden 1. Toshiba Satellite M45 Keyboard Replacement, Keyboard: adım 1, 3 resimden 2. Toshiba Satellite M45 Keyboard Replacement, Keyboard: adım 1, 3 resimden 3.
    • Carefully use the blue iFixit Opening Tool to pry the panel above the keyboard from the left and right side.
    • Push back the screen until it is flat with the laptop.
    • Gently remove the clips that connect the panel to the screen.
  2. Toshiba Satellite M45 Keyboard Replacement: adım 2, 3 resimden 1. Toshiba Satellite M45 Keyboard Replacement: adım 2, 3 resimden 2. Toshiba Satellite M45 Keyboard Replacement: adım 2, 3 resimden 3.
    • Use the Phillips #1 screwdriver to remove the two screws.
    • Gently pry the keyboard from the laptop using the blue iFixit opening tool.
    • Slowly lift the keyboard away from the laptop.
    • Remove the ribbon that connects to the laptop.
    • Ensure you remove the keyboard slowly to avoid damaging the ribbon cable.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Aryn Pauly
1 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-42, Garner Spring 2010 Cal Poly, Team 10-42, Garner Spring 2010 üyesi
CPSU-GARNER-S10S10G42
5 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 20
Her zaman: 8,413
