Ana içeriğe geç
Toshiba Satellite M55-S135 Battery Replacement
  1. Toshiba Satellite M55-S135 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Orient the laptop so that it is closed, faced down, and the battery is facing away from you.
    • Slide the unlock switch in the top left-hand corner to the left/unlock position.
  2. Toshiba Satellite M55-S135 Battery Replacement: adım 2, 1 resimden 1.
    • Hold the switch in upper right-hand corner to the right.
    • With the switch held open, pull the battery straight away from the laptop.
Sonuç
Matthew Trinh
63 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-11, Maness Winter 2013 Cal Poly, Team 7-11, Maness Winter 2013 üyesi
CPSU-MANESS-W13S7G11
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 668
