Ana içeriğe geç
Toshiba Satellite M55-S135 Optical Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite M55-S135 Optical Drive Replacement, RAM: adım 1, 1 resimden 1.
    • Orient the laptop so that it is closed, faced down and has the battery facing away from you.
    • Use the Phillips 00 screwdriver to remove the 7.50mm screw from the panel.
  2. Toshiba Satellite M55-S135 Optical Drive Replacement: adım 2, 1 resimden 1.
    • Carefully remove the cover to reveal the RAM compartment.
  3. Toshiba Satellite M55-S135 Optical Drive Replacement: adım 3, 2 resimden 1. Toshiba Satellite M55-S135 Optical Drive Replacement: adım 3, 2 resimden 2.
    • Rotate the laptop 90 degrees clockwise.
    • Pull back the two silver clips that hold the RAM in place.
    • Gently pull the RAM out of the slot and lift up to remove the RAM from the laptop.
  4. Toshiba Satellite M55-S135 Optical Drive Replacement, Optical Drive: adım 4, 1 resimden 1.
    • Use the Phillips #00 screwdriver to remove the 6.50mm screw holding the gray metal bracket in place.
  5. Toshiba Satellite M55-S135 Optical Drive Replacement: adım 5, 1 resimden 1.
    • Turn the laptop 180 degrees then tilt the near side up.
    • Push the back side of the optical drive out of the laptop using the plastic opening tool.
  6. Toshiba Satellite M55-S135 Optical Drive Replacement: adım 6, 1 resimden 1.
    • Pull the optical drive out of the laptop using your fingers.
  7. Toshiba Satellite M55-S135 Optical Drive Replacement: adım 7, 1 resimden 1.
    • Using the Phillips 00 screwdriver, unscrew the two 2.50mm screws that connect the metal bracket to the optical drive.
    • Remove the bracket from optical drive.
Sonuç
Yuheng Huang
13 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 7-11, Maness Winter 2013 Cal Poly, Team 7-11, Maness Winter 2013 üyesi
CPSU-MANESS-W13S7G11
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 658
