Ana içeriğe geç
Toshiba Satellite M55-S135 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite M55-S135 RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Orient the laptop so that it is closed, faced down and has the battery facing away from you.
    • Use the Phillips 00 screwdriver to remove the 7.50mm screw from the panel.
  2. Toshiba Satellite M55-S135 RAM Replacement: adım 2, 1 resimden 1.
    • Carefully remove the cover to reveal the RAM compartment.
  3. Toshiba Satellite M55-S135 RAM Replacement: adım 3, 2 resimden 1. Toshiba Satellite M55-S135 RAM Replacement: adım 3, 2 resimden 2.
    • Rotate the laptop 90 degrees clockwise.
    • Pull back the two silver clips that hold the RAM in place.
    • Gently pull the RAM out of the slot and lift up to remove the RAM from the laptop.
Sonuç
Matthew Trinh
63 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-11, Maness Winter 2013 Cal Poly, Team 7-11, Maness Winter 2013 üyesi
CPSU-MANESS-W13S7G11
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 1,369
