Ana içeriğe geç
Toshiba Satellite P105-S6147 RAM Replacement
  1. Toshiba Satellite P105-S6147 RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Begin with the laptop laying down on a flat surface, with the bottom facing up.
  2. Toshiba Satellite P105-S6147 RAM Replacement: adım 2, 3 resimden 1. Toshiba Satellite P105-S6147 RAM Replacement: adım 2, 3 resimden 2. Toshiba Satellite P105-S6147 RAM Replacement: adım 2, 3 resimden 3.
    • Remove the battery from the device.
    • The battery is located in the bottom, left hand corner of the device.
    • Slide the lock switch to the unlocked position.
    • Slide the release lever towards the unlock switch. The battery should now rotate out of its dock in the laptop.
  3. Toshiba Satellite P105-S6147 RAM Replacement: adım 3, 2 resimden 1. Toshiba Satellite P105-S6147 RAM Replacement: adım 3, 2 resimden 2.
    • Open the casing directly above the battery.
    • Use a Phillips #0 screwdriver to remove two 4 mm screws located at the top of the casing.
    • Once the cover is removed the RAM sticks will be visible.
  4. Toshiba Satellite P105-S6147 RAM Replacement: adım 4, 2 resimden 1. Toshiba Satellite P105-S6147 RAM Replacement: adım 4, 2 resimden 2.
    • Use a nylon spudger to disconnect the tabs from the RAM. The tabs are located on either side of the RAM.
    • Apply light, outward force to the tabs.
  5. Toshiba Satellite P105-S6147 RAM Replacement: adım 5, 3 resimden 1. Toshiba Satellite P105-S6147 RAM Replacement: adım 5, 3 resimden 2. Toshiba Satellite P105-S6147 RAM Replacement: adım 5, 3 resimden 3.
    • Use the iFixit opening tool to apply light pressure to the bottom of the upper RAM stick.
    • The RAM stick should come loose and be removable by hand.
    • Repeat the previous steps to remove the lower RAM stick.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 200
