Ana içeriğe geç
Toshiba Satellite P205-S8811 Disk Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite P205-S8811 Disk Drive Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite P205-S8811 Disk Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the laptop over so the bottom is facing upward and the battery is on top.
    • Slide the tab below the battery to the left.
  2. Toshiba Satellite P205-S8811 Disk Drive Replacement: adım 2, 2 resimden 1. Toshiba Satellite P205-S8811 Disk Drive Replacement: adım 2, 2 resimden 2.
    • Slide and hold the tab on the right side of the battery to the right.
    • While holding the right tab, slide the battery upward and out its socket.
  3. Toshiba Satellite P205-S8811 Disk Drive Replacement, Disk Drive: adım 3, 1 resimden 1.
    • Remove the 8mm Phillips #1 screw that holds the disk drive in place.
  4. Toshiba Satellite P205-S8811 Disk Drive Replacement: adım 4, 1 resimden 1.
    • Use a plastic opening tool to pry out the disk drive.
  5. Toshiba Satellite P205-S8811 Disk Drive Replacement: adım 5, 2 resimden 1. Toshiba Satellite P205-S8811 Disk Drive Replacement: adım 5, 2 resimden 2.
    • Once the disk drive becomes loose, slowly slide it out and set it aside.
Sonuç
Bradley Johnson
214 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-8, Amido Winter 2014 Cal Poly, Team 2-8, Amido Winter 2014 üyesi
CPSU-AMIDO-W14S2G8
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 439
