Ana içeriğe geç
Toshiba Satellite P205-S8811 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite P205-S8811 Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite P205-S8811 Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the laptop over so the bottom is facing upward and the battery is on top.
    • Slide the tab below the battery to the left.
  2. Toshiba Satellite P205-S8811 Hard Drive Replacement: adım 2, 2 resimden 1. Toshiba Satellite P205-S8811 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Slide and hold the tab on the right side of the battery to the right.
    • While holding the right tab, slide the battery upward and out its socket.
  3. Toshiba Satellite P205-S8811 Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Use a #1 Phillips screwdriver to take out the 8mm Phillips #1 screw holding the hard drive panel on.
  4. Toshiba Satellite P205-S8811 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Place one finger under the tab of the hard drive panel and lift up with medium force.
  5. Toshiba Satellite P205-S8811 Hard Drive Replacement: adım 5, 2 resimden 1. Toshiba Satellite P205-S8811 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Hold the black tab attached to the hard drive and pull with medium force to the side that the tab is on. This will pull the hard drive out of it's socket.
  6. Toshiba Satellite P205-S8811 Hard Drive Replacement: adım 6, 2 resimden 1. Toshiba Satellite P205-S8811 Hard Drive Replacement: adım 6, 2 resimden 2.
    • Use a #1 Phillips screwdriver to unscrew the four 4mm Phillips #1 screws (2 on each side) holding the brackets to the hard drive.
    • With the screws undone, the brackets should come right off. Next, pull on the black tab again to pull the cover off of the hard drive.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew Meyer
245 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-8, Amido Winter 2014 Cal Poly, Team 2-8, Amido Winter 2014 üyesi
CPSU-AMIDO-W14S2G8
4 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
There is a missing step between 4 and 5.
- Remove the screw(s) that hold the HDD assembly in its compartment.
...only then can you move on to step 5.
Robert Cartier - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,133
