Giriş
If your keyboard is malfunctioning and you want to replace it, or you need to take it out to get to a part underneath it, then use this guide to learn how to do so.
Neye ihtiyacın var
Flip the laptop over so the bottom is facing upward and the battery is on top.
Slide the tab below the battery to the left.
Place the head of a plastic opening tool underneath the plastic strip lining the top of the keyboard, right above the "PGUP" button.
Next, pull the strip up using a plastic opening tool with a light force, until it pops off.
Lightly lift up on the keyboard from one of its top corners and pull it towards the screen so you can safely remove the ribbon cable.
At the base of the ribbon cable, there is a tiny tab that runs across the width of the connector. Flip it up. You can now pull the ribbon cable free with no resistance towards the monitor.
With the cable unplugged, the keyboard can be lifted away from the laptop.
