Ana içeriğe geç
Toshiba Satellite P205-S8811 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite P205-S8811 RAM Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite P205-S8811 RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the laptop over so the bottom is facing upward and the battery is on top.
    • Slide the tab below the battery to the left.
  2. Toshiba Satellite P205-S8811 RAM Replacement: adım 2, 2 resimden 1. Toshiba Satellite P205-S8811 RAM Replacement: adım 2, 2 resimden 2.
    • Slide and hold the tab on the right side of the battery to the right.
    • While holding the right tab, slide the battery upward and out its socket.
  3. Toshiba Satellite P205-S8811 RAM Replacement, RAM: adım 3, 1 resimden 1.
    • Locate the RAM slot cover on the bottom of the laptop. The RAM slot cover is located near the battery slot.
  4. Toshiba Satellite P205-S8811 RAM Replacement: adım 4, 1 resimden 1.
    • Using a Phillips-head screwdriver, unscrew and remove the screw holding the RAM slot cover in place.
  5. Toshiba Satellite P205-S8811 RAM Replacement: adım 5, 2 resimden 1. Toshiba Satellite P205-S8811 RAM Replacement: adım 5, 2 resimden 2.
    • Lift and remove the RAM slot cover.
  6. Toshiba Satellite P205-S8811 RAM Replacement: adım 6, 2 resimden 1. Toshiba Satellite P205-S8811 RAM Replacement: adım 6, 2 resimden 2.
    • To remove the first RAM chip, gently press outward on the tabs on both sides of the chip
    • The RAM chip should pop up after releasing the tabs.
  7. Toshiba Satellite P205-S8811 RAM Replacement: adım 7, 1 resimden 1.
    • Using your fingers, remove the RAM chip by gently pulling it out of the RAM slot.
  8. Toshiba Satellite P205-S8811 RAM Replacement: adım 8, 2 resimden 1. Toshiba Satellite P205-S8811 RAM Replacement: adım 8, 2 resimden 2.
    • To remove the second RAM chip, repeat the previous steps
Sonuç
Davin
271 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-8, Amido Winter 2014 Cal Poly, Team 2-8, Amido Winter 2014 üyesi
CPSU-AMIDO-W14S2G8
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 453
