Ana içeriğe geç
Toshiba Satellite P205D-S8804 CD Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite P205D-S8804 CD Drive Replacement, Keyboard: adım 1, 1 resimden 1.
    • Place the laptop with the screen facing you and grab the opening tool.
    • Insert it into the top corner of the keyboard and slide it to the right along the length of the keyboard.
    • You will feel the popping sensation as it slides along.
  2. Toshiba Satellite P205D-S8804 CD Drive Replacement: adım 2, 1 resimden 1.
    • Lit up the left side of the small plastic bar at the top of the keyboard.
    • Be careful when removing it, because you will need to apply a bit of force .
  3. Toshiba Satellite P205D-S8804 CD Drive Replacement: adım 3, 1 resimden 1.
    • Use a PH0 screwdriver to unscrew the 4 screws at the top of the keyboard.
  4. Toshiba Satellite P205D-S8804 CD Drive Replacement: adım 4, 1 resimden 1.
    • Lift up the keyboard and pull it toward the screen.
    • The keyboard will still be connected to the motherboard by a ribbon cable.
  5. Toshiba Satellite P205D-S8804 CD Drive Replacement: adım 5, 2 resimden 1. Toshiba Satellite P205D-S8804 CD Drive Replacement: adım 5, 2 resimden 2.
    • To remove the ribbon cable, push upward on the small tabs located on either side of the ribbon.
  6. Toshiba Satellite P205D-S8804 CD Drive Replacement: adım 6, 1 resimden 1.
    • Once the ribbon is released the keyboard can be removed .
  7. Toshiba Satellite P205D-S8804 CD Drive Replacement, CD Drive: adım 7, 1 resimden 1.
    • Flip the computer over with the hinge facing you.
    • Remove one screw that is located in the Toshiba lable on the bottom of the computer.
  8. Toshiba Satellite P205D-S8804 CD Drive Replacement: adım 8, 1 resimden 1.
    • Flip the computer back over and push the metal tab to the right to release the CD drive from its docking port.
  9. Toshiba Satellite P205D-S8804 CD Drive Replacement: adım 9, 1 resimden 1.
    • Remove the CD Drive.
Sonuç
Caroline Camp
1 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 3-2, Whitney Spring 2017 Baylor, Team 3-2, Whitney Spring 2017 üyesi
BU-WHITNEY-S17S3G2
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 134
