Ana içeriğe geç
Toshiba Satellite P50W-C Battery Replacement
Neye ihtiyacın var
  1. Toshiba Satellite P50W-C Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Turn the laptop off, unplug the AC adapter, and any other auxiliary components.
    • Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
  2. Toshiba Satellite P50W-C Battery Replacement: adım 2, 1 resimden 1.
    • Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
  3. Toshiba Satellite P50W-C Battery Replacement: adım 3, 2 resimden 1. Toshiba Satellite P50W-C Battery Replacement: adım 3, 2 resimden 2.
    • Use the spudger to pry under the back cover until it pops off.
  4. Toshiba Satellite P50W-C Battery Replacement, Battery: adım 4, 1 resimden 1.
    • Unscrew the four 5 mm JIS #1 head screws holding the battery to the device and gently remove the battery.
  5. Toshiba Satellite P50W-C Battery Replacement: adım 5, 2 resimden 1. Toshiba Satellite P50W-C Battery Replacement: adım 5, 2 resimden 2.
    • Disconnect the battery from the motherboard by gently pulling out the black connector.
Sonuç
Lawrence Lozada
246 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G2, Cannon Fall 2017 USF Tampa, Team S3-G2, Cannon Fall 2017 üyesi
USFT-CANNON-F17S3G2
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 1,020
