Ana içeriğe geç
Toshiba Satellite P50W-C Mother Board Replacement
Neye ihtiyacın var
  1. Toshiba Satellite P50W-C Mother Board Replacement, Back Cover: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Turn the laptop off, unplug the AC adapter, and any other auxiliary components.
    • Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
  2. Toshiba Satellite P50W-C Mother Board Replacement: adım 2, 1 resimden 1.
    • Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
  3. Toshiba Satellite P50W-C Mother Board Replacement: adım 3, 2 resimden 1. Toshiba Satellite P50W-C Mother Board Replacement: adım 3, 2 resimden 2.
    • Use the spudger to pry under the back cover until it pops off.
  4. Toshiba Satellite P50W-C Mother Board Replacement, Mother Board: adım 4, 3 resimden 1. Toshiba Satellite P50W-C Mother Board Replacement, Mother Board: adım 4, 3 resimden 2. Toshiba Satellite P50W-C Mother Board Replacement, Mother Board: adım 4, 3 resimden 3.
    • Remove all power connections to the motherboard. Including the black and white power connections to the wifi module.
  5. Toshiba Satellite P50W-C Mother Board Replacement: adım 5, 3 resimden 1. Toshiba Satellite P50W-C Mother Board Replacement: adım 5, 3 resimden 2. Toshiba Satellite P50W-C Mother Board Replacement: adım 5, 3 resimden 3.
    • Unscrew the two 7 mm JIS head screws in the fan .
    • Then unscrew the four 2 mm JIS head screws connecting the heat sink to the mother board.
    • Then take out the heat sink and fan.
  6. Toshiba Satellite P50W-C Mother Board Replacement: adım 6, 1 resimden 1.
    • Remove both 3mm JIS head screws connecting the motherboard to the device.
  7. Toshiba Satellite P50W-C Mother Board Replacement: adım 7, 1 resimden 1.
    • Remove 5mm silver Phillips head screw connecting black cover to the motherboard
  8. Toshiba Satellite P50W-C Mother Board Replacement: adım 8, 2 resimden 1. Toshiba Satellite P50W-C Mother Board Replacement: adım 8, 2 resimden 2.
    • Remove all three 5 mm silver JIS head screws connecting the silver cover to the motherboard.
  9. Toshiba Satellite P50W-C Mother Board Replacement: adım 9, 1 resimden 1.
    • You can now gently remove the motherboard from the device.
Sonuç
Brittany Edwards
104 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G2, Cannon Fall 2017 USF Tampa, Team S3-G2, Cannon Fall 2017 üyesi
USFT-CANNON-F17S3G2
4 Üyeler
7 adet Kılavuz yazıldı
1Rehber Yorum
Hi dear,
My laptop bios was crashed,
I need to radius 15 p50w-c-104 bios dump file.
can you help me please.?
labexperiance@gmail.com
thank you
Mustafa SAYIN - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 512
