Ana içeriğe geç
Toshiba Satellite P55-A5312 CD Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite P55-A5312 CD Drive Replacement, CD Drive: adım 1, 2 resimden 1. Toshiba Satellite P55-A5312 CD Drive Replacement, CD Drive: adım 1, 2 resimden 2.
  2. Toshiba Satellite P55-A5312 CD Drive Replacement: adım 2, 1 resimden 1.
    • Locate the CD drive at the lower right hand corner of the laptop.
    • Unscrew any screws that are holding the drive in place. However, there should only be one. The other screws holding the drive in place are also responsible for holding the bottom casing.
  3. Toshiba Satellite P55-A5312 CD Drive Replacement: adım 3, 2 resimden 1. Toshiba Satellite P55-A5312 CD Drive Replacement: adım 3, 2 resimden 2.
    • Carefully remove the CD drive by pulling it from its connection to the motherboard.
    • Replace it by inserting a new CD drive and replacing any screws you have removed.
Sonuç
ohatae
294 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-1, Banghart Winter 2017 Cal Poly, Team 9-1, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S9G1
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 773
