Ana içeriğe geç
Toshiba Satellite P55W-C5200X Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite P55W-C5200X Keyboard Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite P55W-C5200X Keyboard Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite P55W-C5200X Keyboard Replacement, Battery: adım 1, 3 resimden 3.
    • Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
  2. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 2, 1 resimden 1.
    • Use the black nylon spudger to pry the back casing along the edges.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
  3. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 3, 2 resimden 1. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 3, 2 resimden 2.
    • Remove the four 6.0 mm screws that hold the battery in place using the JIS #000 screwdriver.
  4. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 4, 2 resimden 1. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 4, 2 resimden 2.
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  5. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 5, 2 resimden 1. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 5, 2 resimden 2.
    • Gently remove the battery from your device.
  6. Toshiba Satellite P55W-C5200X Keyboard Replacement, RAM: adım 6, 3 resimden 1. Toshiba Satellite P55W-C5200X Keyboard Replacement, RAM: adım 6, 3 resimden 2. Toshiba Satellite P55W-C5200X Keyboard Replacement, RAM: adım 6, 3 resimden 3.
    • For this particular model of the device there will be two sticks of RAM.
    • There are two metal brackets holding each RAM stick in place. Carefully move the metal brackets outward on both sides at the same time.
    • Pull the RAM sticks out.
  7. Toshiba Satellite P55W-C5200X Keyboard Replacement, Fan: adım 7, 3 resimden 1. Toshiba Satellite P55W-C5200X Keyboard Replacement, Fan: adım 7, 3 resimden 2. Toshiba Satellite P55W-C5200X Keyboard Replacement, Fan: adım 7, 3 resimden 3.
    • Remove the two 4.0 mm screws using the Phillips #00 screwdriver.
    • Remove the four 2.0 mm screws using the Phillips #0 screwdriver.
  8. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 8, 2 resimden 1. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 8, 2 resimden 2.
    • Disconnect the fan cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  9. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 9, 2 resimden 1. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 9, 2 resimden 2.
    • Gently remove the fan from your device.
  10. Toshiba Satellite P55W-C5200X Keyboard Replacement, Keyboard: adım 10, 1 resimden 1.
    • Once the fan, ram, and battery are removed, remove the motherboard.
    • Detach the three connecting wires.
    • Remove the white, blue-tipped cable ribbon too.
  11. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 11, 3 resimden 1. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 11, 3 resimden 2. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 11, 3 resimden 3.
    • Remove the three wires that are connected to the motherboard first.
  12. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 12, 2 resimden 1. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 12, 2 resimden 2.
    • Remove the ribbon by using the black nylon spudger to avoid tearing the ribbon.
  13. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 13, 3 resimden 1. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 13, 3 resimden 2. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 13, 3 resimden 3.
    • Use the Phillips #00 screwdriver to remove the three 5.0 mm screws that are holding the metal bracket in place.
    • Gently remove the metal bracket.
  14. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 14, 3 resimden 1. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 14, 3 resimden 2. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 14, 3 resimden 3.
    • Use the Phillips #00 to remove the four 8.0 mm screws that are holding the motherboard in place.
    • After removing all the screws, gently remove the motherboard.
  15. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 15, 3 resimden 1. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 15, 3 resimden 2. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 15, 3 resimden 3.
    • Similar to step 4, there is a metal bracket that must be removed to get to some ports.
    • Use the Phillips #00 screwdriver to remove the three 5.0 mm screws that are holding the metal plate in place.
    • Gently remove the metal bracket off the ports underneath.
  16. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 16, 3 resimden 1. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 16, 3 resimden 2. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 16, 3 resimden 3.
    • Once the ports are accessible, remove four connecting wires from the ports themselves.
    • Be gentle when removing the four wires.
  17. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 17, 2 resimden 1. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 17, 2 resimden 2.
    • Once the connecting wires are removed, remove the 8.0 mm screw of the USB ports, using the Phillips #00 screwdriver.
    • Gently remove the USB ports.
  18. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 18, 3 resimden 1. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 18, 3 resimden 2. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 18, 3 resimden 3.
    • Remove the thirty-three 1.0 mm screws with the Phillips Head #000.
    • Gently remove the metal cover.
  19. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 19, 3 resimden 1. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 19, 3 resimden 2. Toshiba Satellite P55W-C5200X Keyboard Replacement: adım 19, 3 resimden 3.
    • Gently pull on the tab to lift the keyboard from the device.
    • Lastly remove the keyboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Vatthanak Doeung
223 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G2, Botvin Fall 2019 UMass Dartmouth, Team S1-G2, Botvin Fall 2019 üyesi
UMASSD-BOTVIN-F19S1G2
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 24
Her zaman: 1,680
