Ana içeriğe geç
Toshiba Satellite P55W-C5200X RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite P55W-C5200X RAM Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite P55W-C5200X RAM Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite P55W-C5200X RAM Replacement, Battery: adım 1, 3 resimden 3.
    • Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
  2. Toshiba Satellite P55W-C5200X RAM Replacement: adım 2, 1 resimden 1.
    • Use the black nylon spudger to pry the back casing along the edges.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
  3. Toshiba Satellite P55W-C5200X RAM Replacement: adım 3, 2 resimden 1. Toshiba Satellite P55W-C5200X RAM Replacement: adım 3, 2 resimden 2.
    • Remove the four 6.0 mm screws that hold the battery in place using the JIS #000 screwdriver.
  4. Toshiba Satellite P55W-C5200X RAM Replacement: adım 4, 2 resimden 1. Toshiba Satellite P55W-C5200X RAM Replacement: adım 4, 2 resimden 2.
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  5. Toshiba Satellite P55W-C5200X RAM Replacement: adım 5, 2 resimden 1. Toshiba Satellite P55W-C5200X RAM Replacement: adım 5, 2 resimden 2.
    • Gently remove the battery from your device.
  6. Toshiba Satellite P55W-C5200X RAM Replacement, RAM: adım 6, 3 resimden 1. Toshiba Satellite P55W-C5200X RAM Replacement, RAM: adım 6, 3 resimden 2. Toshiba Satellite P55W-C5200X RAM Replacement, RAM: adım 6, 3 resimden 3.
    • For this particular model of the device there will be two sticks of RAM.
    • There are two metal brackets holding each RAM stick in place. Carefully move the metal brackets outward on both sides at the same time.
    • Pull the RAM sticks out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Hadi Termos
241 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G2, Botvin Fall 2019 UMass Dartmouth, Team S1-G2, Botvin Fall 2019 üyesi
UMASSD-BOTVIN-F19S1G2
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 23
Her zaman: 954
