Ana içeriğe geç
Toshiba Satellite P55W-C5316 Back Panel Replacement
Neye ihtiyacın var
  1. Toshiba Satellite P55W-C5316 Back Panel Replacement, Back Panel: adım 1, 2 resimden 1. Toshiba Satellite P55W-C5316 Back Panel Replacement, Back Panel: adım 1, 2 resimden 2.
    • To prevent injury, ensure the laptop is powered off before starting your work.
    • Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
  2. Toshiba Satellite P55W-C5316 Back Panel Replacement: adım 2, 3 resimden 1. Toshiba Satellite P55W-C5316 Back Panel Replacement: adım 2, 3 resimden 2. Toshiba Satellite P55W-C5316 Back Panel Replacement: adım 2, 3 resimden 3.
    • Be careful to not crack the panel where the USB and power cord ports are.
    • Insert the opening tool in between the back panel and the laptop to pry it open.
    • The back panel is magnetically attached at the front of the laptop so you may have to move the opening tool along the length of the panel.
    • Lift the panel from the front off of the laptop.
Sonuç
Nicholas Caswell
117 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G2, Bailey Fall 2017 UMass Dartmouth, Team S3-G2, Bailey Fall 2017 üyesi
UMASSD-BAILEY-F17S3G2
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 950
