Ana içeriğe geç
Toshiba Satellite P55W-C5316 Battery Replacement
Neye ihtiyacın var
  1. Toshiba Satellite P55W-C5316 Battery Replacement, Back Panel: adım 1, 2 resimden 1. Toshiba Satellite P55W-C5316 Battery Replacement, Back Panel: adım 1, 2 resimden 2.
    • To prevent injury, ensure the laptop is powered off before starting your work.
    • Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
  2. Toshiba Satellite P55W-C5316 Battery Replacement: adım 2, 3 resimden 1. Toshiba Satellite P55W-C5316 Battery Replacement: adım 2, 3 resimden 2. Toshiba Satellite P55W-C5316 Battery Replacement: adım 2, 3 resimden 3.
    • Be careful to not crack the panel where the USB and power cord ports are.
    • Insert the opening tool in between the back panel and the laptop to pry it open.
    • The back panel is magnetically attached at the front of the laptop so you may have to move the opening tool along the length of the panel.
    • Lift the panel from the front off of the laptop.
    Please where to buy this back panel , thank you
    Yvette Menthong Mana - Yanıt
  3. Toshiba Satellite P55W-C5316 Battery Replacement, Battery: adım 3, 3 resimden 1. Toshiba Satellite P55W-C5316 Battery Replacement, Battery: adım 3, 3 resimden 2. Toshiba Satellite P55W-C5316 Battery Replacement, Battery: adım 3, 3 resimden 3.
    • The battery is located in the bottom right corner of the laptop.
    • Remove the four .5mm Phillips head screws on the battery using the PH1 screwdriver.
  4. Toshiba Satellite P55W-C5316 Battery Replacement: adım 4, 2 resimden 1. Toshiba Satellite P55W-C5316 Battery Replacement: adım 4, 2 resimden 2.
    • Do not tug on the cord or battery. Instead, pull evenly on the connector.
    • Lift the battery and gently pull out the bundled cable connector.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Alec Bonnell
497 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G2, Bailey Fall 2017 UMass Dartmouth, Team S3-G2, Bailey Fall 2017 üyesi
UMASSD-BAILEY-F17S3G2
3 Üyeler
7 adet Kılavuz yazıldı
1Rehber Yorum
Hello, please I've been searching and searching online to get motherboard for Toshiba Satellite P55W-C5316 but i don't seen to find any. Can anyone lead me to get one to buy.
Owusu Bright - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 28
Her zaman: 3,092
