Ana içeriğe geç
Toshiba Satellite P55W-C5316 Fan Replacement
Neye ihtiyacın var
  1. Toshiba Satellite P55W-C5316 Fan Replacement, Back Panel: adım 1, 2 resimden 1. Toshiba Satellite P55W-C5316 Fan Replacement, Back Panel: adım 1, 2 resimden 2.
    • To prevent injury, ensure the laptop is powered off before starting your work.
    • Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
  2. Toshiba Satellite P55W-C5316 Fan Replacement: adım 2, 3 resimden 1. Toshiba Satellite P55W-C5316 Fan Replacement: adım 2, 3 resimden 2. Toshiba Satellite P55W-C5316 Fan Replacement: adım 2, 3 resimden 3.
    • Be careful to not crack the panel where the USB and power cord ports are.
    • Insert the opening tool in between the back panel and the laptop to pry it open.
    • The back panel is magnetically attached at the front of the laptop so you may have to move the opening tool along the length of the panel.
    • Lift the panel from the front off of the laptop.
  3. Toshiba Satellite P55W-C5316 Fan Replacement, Fan: adım 3, 1 resimden 1.
    • Remove both screws from the fan.
  4. Toshiba Satellite P55W-C5316 Fan Replacement: adım 4, 2 resimden 1. Toshiba Satellite P55W-C5316 Fan Replacement: adım 4, 2 resimden 2.
    • Remove the screws securing the 4 corners of the heatsink.
    • Gently remove the heatsink. Keep in mind thermal paste is used and it may be slightly difficult to remove.
  5. Toshiba Satellite P55W-C5316 Fan Replacement: adım 5, 3 resimden 1. Toshiba Satellite P55W-C5316 Fan Replacement: adım 5, 3 resimden 2. Toshiba Satellite P55W-C5316 Fan Replacement: adım 5, 3 resimden 3.
    • Remove the small, beige colored connector securing the fan to the laptop and remove the fan and heatsink assembly from the laptop.
Sonuç
Zeyad Ali
349 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G1, Harley Fall 2019 IUPUI, Team S2-G1, Harley Fall 2019 üyesi
IUPUI-HARLEY-F19S2G1
3 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 430
