Giriş
Use this guide to remove the Toshiba Satellite P55t-A5116 battery.
Neye ihtiyacın var
Use the #PH0 screw head, remove 4 (5.7mm) screws.
Unplug the battery's 10 pin connector and gently lift the battery out of the laptop.
12 farklı kişi bu kılavuzu tamamladı.
9 Yorum
The screws for the battery are in very tight and I'm having trouble unscrewing them
I'm having difficulty unplugging the 10 pin connector. Afraid if I pull too hard it will pull the wires out. Any suggestions?
Just wiggle it back-and-forth a bit and it should come out. I just change my own battery.
