Ana içeriğe geç
Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement
Neye ihtiyacın var
  1. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement, Back Casing: adım 1, 2 resimden 1. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement, Back Casing: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Close laptop and turn it upside down
    • Remove the 14 circular rubber covers with tweezers along with one smaller more cylindrical rubber cover.
  2. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement: adım 2, 2 resimden 1. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement: adım 2, 2 resimden 2.
    • Using the #PH0 screw head, remove 14 (5.7 mm) screws from the back casing.
  3. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement: adım 3, 3 resimden 1. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement: adım 3, 3 resimden 2. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement: adım 3, 3 resimden 3.
    • Gently pry off the bottom case with the plastic opening tools.
    • Find the seam between the back case and the rest of the laptop casing.
  4. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement, Battery: adım 4, 2 resimden 1. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement, Battery: adım 4, 2 resimden 2.
    • Use the #PH0 screw head, remove 4 (5.7mm) screws.
    • Unplug the battery's 10 pin connector and gently lift the battery out of the laptop.
  5. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement: adım 5, 1 resimden 1.
    • Gently remove battery from the laptop.
  6. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement, Fan & CPU Cooler: adım 6, 1 resimden 1.
    • Using a PH0 screwdriver, remove 2 (5.7mm) screws.
    • Using a PH0 screwdriver, remove 4 (3.68mm) screws.
  7. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement: adım 7, 2 resimden 1. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement: adım 7, 2 resimden 2.
    • Unplug the 3 pin connector
    • Remove fan.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 21
Her zaman: 1,787
