Ana içeriğe geç
Toshiba Satellite P55t-A5116 Power Jack Replacement
Neye ihtiyacın var
  1. Toshiba Satellite P55t-A5116 Power Jack Replacement, Back Casing: adım 1, 2 resimden 1. Toshiba Satellite P55t-A5116 Power Jack Replacement, Back Casing: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Close laptop and turn it upside down
    • Remove the 14 circular rubber covers with tweezers along with one smaller more cylindrical rubber cover.
  2. Toshiba Satellite P55t-A5116 Power Jack Replacement: adım 2, 2 resimden 1. Toshiba Satellite P55t-A5116 Power Jack Replacement: adım 2, 2 resimden 2.
    • Using the #PH0 screw head, remove 14 (5.7 mm) screws from the back casing.
  3. Toshiba Satellite P55t-A5116 Power Jack Replacement: adım 3, 3 resimden 1. Toshiba Satellite P55t-A5116 Power Jack Replacement: adım 3, 3 resimden 2. Toshiba Satellite P55t-A5116 Power Jack Replacement: adım 3, 3 resimden 3.
    • Gently pry off the bottom case with the plastic opening tools.
    • Find the seam between the back case and the rest of the laptop casing.
  4. Toshiba Satellite P55t-A5116 Power Jack Replacement, Battery: adım 4, 2 resimden 1. Toshiba Satellite P55t-A5116 Power Jack Replacement, Battery: adım 4, 2 resimden 2.
    • Use the #PH0 screw head, remove 4 (5.7mm) screws.
    • Unplug the battery's 10 pin connector and gently lift the battery out of the laptop.
  5. Toshiba Satellite P55t-A5116 Power Jack Replacement: adım 5, 1 resimden 1.
    • Gently remove battery from the laptop.
  6. Toshiba Satellite P55t-A5116 Power Jack Replacement, Power Jack: adım 6, 3 resimden 1. Toshiba Satellite P55t-A5116 Power Jack Replacement, Power Jack: adım 6, 3 resimden 2. Toshiba Satellite P55t-A5116 Power Jack Replacement, Power Jack: adım 6, 3 resimden 3.
    • Using the #PH0 screw head, remove 2 (5.7 mm) screws.
    • Remove metal plate.
    • Using the #PH0 screw head remove 1 (5.7mm) screw and 1 (4.15mm) screw.
  7. Toshiba Satellite P55t-A5116 Power Jack Replacement: adım 7, 2 resimden 1. Toshiba Satellite P55t-A5116 Power Jack Replacement: adım 7, 2 resimden 2.
    • Use the plastic opening tool to push the left hinge up.
  8. Toshiba Satellite P55t-A5116 Power Jack Replacement: adım 8, 2 resimden 1. Toshiba Satellite P55t-A5116 Power Jack Replacement: adım 8, 2 resimden 2.
    • Gently pull up the power jack. Follow the cord until you reach the connector.
    • Unplug the 4 pin connector and remove from laptop
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Absolutely terrific tutorial! This helped me immensely. My laptop is Toshiba Satellite P55T-5202 and has the same layout as this. This worked perfectly.
I purchased the part form Amazon, btw. Its a DC Power Jack Replacement
Alampana - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 19
Her zaman: 3,847
