Ana içeriğe geç
Giriş
Through this guide you will learn to replace the fan inside of your laptop. Make sure you have the proper tools in order to complete the repair. This kind of repair is usually done to fix the problem of your laptop overheating.
  1. Slide the tabs apart from each other.
    • Slide the tabs apart from each other.
  2. Lift the battery upwards and remove it from the device. Lift the battery upwards and remove it from the device.
    • Lift the battery upwards and remove it from the device.
  3. Using a Phillips #1 screwdriver, remove the screw from the back cover. Remove the back cover from the device.
    • Using a Phillips #1 screwdriver, remove the screw from the back cover.
    • Remove the back cover from the device.
  4. Remove the optical drive from the device. Remove the optical drive from the device. Remove the optical drive from the device.
    • Remove the optical drive from the device.
  5. Using a Phillips #1 screwdriver, unscrew the remaining screws that are visible on the laptop. Remove the back cover from your device.
    • Using a Phillips #1 screwdriver, unscrew the remaining screws that are visible on the laptop.
    • Remove the back cover from your device.
  6. Using a Phillips #1 screwdriver, remove the screw connecting the Wi-Fi adapter to the motherboard. Remove the Wi-Fi adapter from the device. Remove the Wi-Fi adapter from the device.
    • Using a Phillips #1 screwdriver, remove the screw connecting the Wi-Fi adapter to the motherboard.
    • Remove the Wi-Fi adapter from the device.
  7. Using a Phillips #1 screwdriver, unscrew the 6 remaining screws attached to the fan. Unplug the connector connecting the fan to the motherboard.
    • Using a Phillips #1 screwdriver, unscrew the 6 remaining screws attached to the fan.
    • Unplug the connector connecting the fan to the motherboard.
    • Remove the fan from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 34
Her zaman: 804
