Ana içeriğe geç
Toshiba Satellite P75-A7100 Motherboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite P75-A7100 Motherboard Replacement, Fan: adım 1, 2 resimden 1. Toshiba Satellite P75-A7100 Motherboard Replacement, Fan: adım 1, 2 resimden 2.
    • Using a Phillips #1 screwdriver, unscrew the 6 remaining screws attached to the fan.
    • Unplug the connector connecting the fan to the motherboard.
    • Remove the fan from the device.
  2. Toshiba Satellite P75-A7100 Motherboard Replacement, Motherboard: adım 2, 1 resimden 1.
    • Take out all remaining screws in the motherboard.
  3. Toshiba Satellite P75-A7100 Motherboard Replacement: adım 3, 3 resimden 1. Toshiba Satellite P75-A7100 Motherboard Replacement: adım 3, 3 resimden 2. Toshiba Satellite P75-A7100 Motherboard Replacement: adım 3, 3 resimden 3.
    • Disconnect the purple and orange ZIF connectors from the motherboard.
  4. Toshiba Satellite P75-A7100 Motherboard Replacement: adım 4, 2 resimden 1. Toshiba Satellite P75-A7100 Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove cartridges from laptop by lifting them up.
  5. Toshiba Satellite P75-A7100 Motherboard Replacement: adım 5, 1 resimden 1.
    • Disconnect all wires from the motherboard and replace motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Thanks you very much. Have a nice day
janavas10 - Yanıt
Gracias. Pero no veo que al remover la placa madre pueda acceder a las 2 ranuras de RAM que están justo debajo del teclado o debajo de los buffers de sonido. Entiendo que debo quitar la placa que cubre el teclado que es una pieza.
janavas10 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 3,760
