Ana içeriğe geç
Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement
Neye ihtiyacın var
  1. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the tabs apart from each other.
  2. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: adım 2, 2 resimden 1. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: adım 2, 2 resimden 2.
    • Lift the battery upwards and remove it from the device.
  3. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement, Wi-Fi Adapter: adım 3, 2 resimden 1. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement, Wi-Fi Adapter: adım 3, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the screw from the back cover.
    • Remove the back cover from the device.
  4. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: adım 4, 3 resimden 1. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: adım 4, 3 resimden 2. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: adım 4, 3 resimden 3.
    • Remove the optical drive from the device.
  5. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: adım 5, 2 resimden 1. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: adım 5, 2 resimden 2.
    • Using a Phillips #1 screwdriver, unscrew the remaining screws that are visible on the laptop.
    • Remove the back cover from your device.
  6. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: adım 6, 3 resimden 1. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: adım 6, 3 resimden 2. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: adım 6, 3 resimden 3.
    • Using a Phillips #1 screwdriver, remove the screw connecting the Wi-Fi adapter to the motherboard.
    • Remove the Wi-Fi adapter from the device.
Sonuç
1Rehber Yorum
¿Como reemplazo el cable blanco?, esta cortado.
Henry Rivera - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 1,113
