Ana içeriğe geç
Toshiba Satellite P755 S5390 Touchpad Repair
Neye ihtiyacın var
  1. Toshiba Satellite P755 S5390 Touchpad Repair, Toshiba Satellite P755 S5390 Touchpad Repair: adım 1, 3 resimden 1. Toshiba Satellite P755 S5390 Touchpad Repair, Toshiba Satellite P755 S5390 Touchpad Repair: adım 1, 3 resimden 2. Toshiba Satellite P755 S5390 Touchpad Repair, Toshiba Satellite P755 S5390 Touchpad Repair: adım 1, 3 resimden 3.
    • Make sure that your laptop is powered off before starting.
    • Close the cover and turn the laptop over so that the spine is facing away from you.
  2. Toshiba Satellite P755 S5390 Touchpad Repair: adım 2, 2 resimden 1. Toshiba Satellite P755 S5390 Touchpad Repair: adım 2, 2 resimden 2.
    • Slide and hold the locks on both sides of the battery to the unlocked position.
    • Slide and lift the battery out of its compartment.
  3. Toshiba Satellite P755 S5390 Touchpad Repair: adım 3, 1 resimden 1.
    • Use the Philips #1 screwdriver to remove the 15 screws from the base of the laptop.
    • Keep track of these screws, you will need them in reassembly.
  4. Toshiba Satellite P755 S5390 Touchpad Repair: adım 4, 1 resimden 1.
    • Turn the laptop back over.
    • Open the cover.
  5. Toshiba Satellite P755 S5390 Touchpad Repair: adım 5, 3 resimden 1. Toshiba Satellite P755 S5390 Touchpad Repair: adım 5, 3 resimden 2. Toshiba Satellite P755 S5390 Touchpad Repair: adım 5, 3 resimden 3.
    • Using either the iFixit opening tool or your hands, gently remove the keyboard from the base panel.
    • Do not touch the motherboard.
  6. Toshiba Satellite P755 S5390 Touchpad Repair: adım 6, 2 resimden 1. Toshiba Satellite P755 S5390 Touchpad Repair: adım 6, 2 resimden 2.
    • Check if the touch pad cable is plugged into the ZIF connector on the motherboard.
  7. Toshiba Satellite P755 S5390 Touchpad Repair: adım 7, 3 resimden 1. Toshiba Satellite P755 S5390 Touchpad Repair: adım 7, 3 resimden 2. Toshiba Satellite P755 S5390 Touchpad Repair: adım 7, 3 resimden 3.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Dominic Oldani
237 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 6,835
